The reason pool supply companies would recommend an inline chlorine feeder over a SWG is that they make MUCH higher profits on trichlor tabs and all the other chemicals you will need once your stabilzer goes too high to keep the algae at bay then they do over a few bags of salt and a few jugs of acid you will need with your SWG!
