Results 1 to 3 of 3
Thread: bleach ? help
    Jul 2006
    Default bleach ? help
    i have a reqtangle pool 3' to 9.5' 20 by 40 how much bleach do i use and how often should i put it in i am new to this so thanks in advance
    Jul 2006
    SE Georgia
    Default Re: bleach ? help
    Search this site or the internet and find a program called bleachcalc262.exe. According to this program, in order to rasie the chlorine level in my pool by 1.0 ppm, it told me to add 1 gallon of bleach. My pool is apprximately 40K gallons. I added a gallon of 6% bleach and chlorine increased by 1 ppm. Bleachcalc works great!
    40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
    Been using BBB for over a year! Excellent results!
    You need to figure how many gallons your pool holds, and then post a current test level (using a drop-based kit, not strips) for CYA in order for us to help you with that question.
