CYA Levels
Last Friday I tested my water, and the CYA was very high, off the scale of my tester(WalMart).. I drained 1/2 the water (abt 13000 gal Gunite pool). Refilled, and took some water the the pool place Sat. Here is their numbers.
TC 5
FC 5
CC 0
PH 7.6
ALK 135
CYA 110
So I drained another 1/2 the pool, and used the last of my CYA test,
My numbers
TC .2
FC .2
PH 7.8
Alk 110
CYA 80
I added some Clorine, and got the TC to 6, and it has stayed there for about 24 hrs..
My first question, is shouldn't 2 drains of 1/2 bring the CYA down more than that? I also assume I need to get that down, then take care of the ALK/PH by Airation??
Les
That does not seem to me that the
- You may not post replies
- You may not edit your posts
Forum Rules
