Thread: Alkalinity -- Whoa! off the chart!
    Jul 2006
    West Central Illinois
    Default Alkalinity -- Whoa! off the chart!
    We just installed a used pool, filled it up, and messed with the filter for a couple of days. I think we are ready to clear up the water and use it.
    Using the Walmart drop test kit my alkalinity is off the chart. Well over 200. CL is around 5 and PH is 7.2. Not sure about CYA but I dumped in 4 lbs which should give me a level of around 30-40.
    I looked at the Bleach Calc to figure out where to begin with the baking soda but I'm unsure.
    I have a 28 ft round AG with a depth of about 3.5 ft.
    Edited to add I am using BBB, of course. : )
    mbar's Avatar
    Ashland, PA
    Default Re: Alkalinity -- Whoa! off the chart!
    Do not use baking soda - it will raise your alkalinity, and you don't need that. If you want to raise your ph you use borax. If it were my pool, I would leave the ph where it is, turn the return jets up so the water bubbles on top - this will raise your ph while lowering your alkalinty. You can continue to lower the alkalinity by bringing your ph back down to 7.2 and continue aerating the water. This is the process to use to bring the alkalintiy down. Continue till you get your alkalinity down to 120. After the ph gets above 7.4 the aeration won't lower the alkalintiy anymore. If you have any other questions, please ask.
    Northeast PA
  1. Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    By heyaim in forum Dealing with Alkalinity and Calcium
    Last Post: 07-22-2012, 07:51 PM
  2. Log Book Or Chart
    By DONNIE in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2006, 12:55 PM
  3. Best Guess Chart
    By cav in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-18-2006, 06:13 PM
  4. Bens Chart
    By Coolflee22 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-01-2006, 11:56 AM
