Thread: just making sure...
    Default just making sure...
    I have an 18' above ground. It's been open for a month, and here are the numbers:
    Cl-3ppm
    ph-7.5
    TA-160
    Cya-25 ppm
    The ph has been rock steady at 7.5. Should I worry about the TA being a little high or not?
    mbar's Avatar
    Ashland, PA
    Default Re: just making sure...
    No, I think your numbers are fine. Welcome to the forum!
    Northeast PA
