I would generally shock if a CC reading was greater than .5 ppm.Originally Posted by maxhiller
As dawndenise clearly pointed out, you are correct(2) also, i assume that i push the existing FC up to 20, and do not simply
add 20ppm worth of chlorine. is this correct ?![]()
Dave
