Results 1 to 10 of 16
Thread: Pool Pilot
    DONNIE is offline Registered+ Thread Analyst DONNIE 0
    Jul 2006
    Oklahoma
    Default Pool Pilot
    Getting ready to install a 6000 gallon fiberglass pool. Have decided to go with the Pool Pilot Digital but am not sure which one. I keep reading to upsize my cell. the 36 says up to 20,000 and the 48 says up to 40,000 gallons. with mine only being 6000 gallons do I really need to upsize my cell?
    Donnie
    Saint Cloud, FL
    Default Re: Pool Pilot
    The SC-36 cell should be adequate for your 6000 gal pool.
    Pat
    Ft Lauderdale, Fl
    Donnie,
    I agree with Pat that the SC-36 would be sufficient. If you go with the SC-48 or SC-60 cell, there are some adjustments on the system that will allow you to not overchlorinate your pool. Again, the benefits of oversizing is that you have longer cell life and warranty.
    Thanks for supporting the Salt Chlorinator industry and for considering Pool Pilot.
    Sean Assam
    Jul 2006
    Oklahoma
    Thanks guys. Like I said, this is a new pool. 1. I fill the pool 2. I get pool chemestry in line 3. I add salt 4. I turn on SWG
    ???? Do I bypass the SWG during the first 3 steps or do I just not turn it on? Does it have a bypass setting?
    Donnie
    Saint Cloud, FL
    If you can disconnect the power supply to the SWCG until the salt is added, there should be no problem. I did that when I replastered the pool and had to wait a month before adding salt. Used trichlor pucks to add CYA, and then changed to bleach.
    Pat.
    Jul 2006
    Oklahoma
    Where do you buy your salt. I noticed Lowes has about 8 different types.
