Results 1 to 10 of 15
Thread: SWG for AG?
    Tennessee
    Default Re: SWG for AG?
    I checked with Artesian pools before salting my pool and was informed it would not void my warranty. I feel that they would void the warranty if there was a problem.
    I will be adding a SWG next year would it ba a problem to install a SWG made for an in-ground pool for the same volume ???
    Ft Lauderdale, Fl
    The main difference with an abg unit is that it is typically sized smaller and has less features than a standard unit, with the "thought" that abg pool owners do not want to spend as much for a salt system. Heck, there are so many abg pools with more water than some in ground pool.
    Steve, to answer your question, Yes, search for the standard in ground models.
    Sean
    Sean Assam
    Jul 2006
    Shepherdsville, KY
    Thanks for your input Sean! I will definitely research the different SWG's out there (now that I know I can use an IG SWG if I need to).
    Tennessee
    Thanks for the info as well. I will be adding one in the spring if I can find the $$$.
    KPROMERO is offline Registered+ Thread Analyst KPROMERO 0
    Broussard, Louisiana
    I have an artesian pool(27' round=17,204 gallons) also and have installed an aquarite to it for 2 years now and in my opinion it was the best money I ever spent.
    Northern Kentucky
    KP,
    what material are your pool walls and bottom rails? steel, alum, resin?? Do you hose off the pool diligently? Do you see any signs of corrosion that would be attributed to the salt and not just the water?
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
