Results 1 to 10 of 14
Thread: Pump Not Pulling Enough Water To Run Properly
    Saint Cloud, FL
    Default Re: Pump Not Pulling Enough Water To Run Properly
    Have you lubed the O-ring on the pump filter basket?
    Are you getting air from the filter?
    Rangeball's suggestion #5 is highly possible.
    Let us know.
    Pat
    Hi,
    Thanks for the responses. We checked the filter basket and the connections and there weren't any air leaks there. How would I go about determining if there is a block in the line? We are VERY green pool owners, thanks again.
    Susan
    IL.
    I'd run a garden hose on full blast from the pump basket back through supply line and see what kind of flow you get.
