Results 1 to 10 of 18
Thread: New Pool... Ozone or Salt?
    Default Re: New Pool... Ozone or Salt?
    Quote Originally Posted by deeze
    OK OK, everyone I talk to in person says the ozone system is the way to go. I've seen two pools running on it and they both say it's the best thing since sliced bread. However, I read bad things on the web. What are your opinions on the ozone systems? I'm in Florida and I'm looking or the least amount of upkeep possible. I have a big 200 gallon salt water tank that takes up most of my "water upkeep" time... ha!
    I hear great things about salt pools too but I'm torn.
    The pool builder swears by it!
    A salt water reef tank and a pool with a salt water chlorine genterator are apples and oranges!
    I have kept salt water tanks for about 30 years now and they can be a lot of work. Using electrolysis to generate chlorine in a swimming pool (by adding salt to the pool and having a SWG installed) makes pool maintenance very easy. I have one on my pool. Ozone does destroy chlorine and chlorine destroys ozone. Ozone works better with bromine since it will reactivate the bromine bank in the water.
    Just adding salt to your pool without the SWG will just give you salty water (but even that has some advantatges!)
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Dont waste your money on the Ozone.
    http://www.poolsolutions.com/tips/tip48.html
    I have an Ozone/SWG and I can tell you that the Ozone doesnt do squat. A good SWG is all you need. Bigger is better.
    Some people have hobbies.....I have a pool.
    North Texas
    Wink Re: New Pool... Ozone or Salt?
    I have a Delzone TrioPure 50 in a 40K pool and so far I am happy with the water quality. The Water is CRYSTAL clear compared to almost every other pool I look at. This is a new pool, 4 months old, but so far I am happy with the system. The trio pure does have a SWG also for the residual chlorine sanitation. One thing I like is how clean the 2"glass waterline tiles are. Some of my neighbors have oil and gunk on their waterline tiles that I do not get. Only delta I can see is Ozone. Ozone has benefits that are often overlooked. One is the ability to kill organisms that Chlorine can not kill. Never should need to shock the pool either.
    Do your homework on Ozone (Corona Discharge) is not the same league as the typical bulb ozone systems. I know the website is pretty negative about Ozone, which for the average bear may be accurate. I am told you should not confuse Corona discharge units to the low end units. Also the cell replacement cost for the SWG in the Trio is about 400.00 which is a fair price. I was not real impressed with the Trio Pure system when I started up the pool, it was cloudy and seemed to be murky, then about a week or two later it was awesome. Now it is amazing, I can see every imperfection in my pool plaster, LOL.
    No not affiliated with Delzone, I have had good results with the triopure product so far. Just sharing my current results, could change tomorrow and if it does I will let you know. FYI This weeks water test is CH 2, Ph7.4, Cal 200, Alk 70, CYA70.
    I have my flak jacket on so let em rip,
    Quote Originally Posted by Big_D
    My pool was a dark green frog pond when it was first stated up. All it took to make it sparkling clear was a good shocking with bleach and turning on the SWG. In just over 24 hours it looked like the picture you see in my avitar and has been that way ever since!
    tonyl is offline Registered+ Thread Analyst tonyl 0
    Indiana
    Big D....since you have both Ozone and Salt it's hard to brag about one over the other. I've been a SWG user for several years now and haven't had to shock either, except upon opening. My pool water was also dark green when I opened and in 24 hrs was crystal clear as well.
    A friend of mine has a UV Ozone system and loves it and doesn't have to shock either. The only thing he dislikes is trying to keep his chlorine residual stable. I don't recommend ozone when you still have to have chlorine, when you can have a SWG and not have to have ozone.
    Wisconsin
    I also have the Trio-pure 50.
    I cant compare it to other systems but from what I now know about Ozone.....I cant see that it does anything. Even if I turn the Ozone part of the Trio-pure off it performs exactly the same.
    The SWG part of the Trio-pure is marginally good and for the price I cant help but feel I would have been better off with the "autopilot" or other "SWG only" systems favored on these forums.
    North Texas
    I am not trying to compare SWG vs Ozone, the Trio has both so not ozone or chlorine alone. Not sure how I could be bragging about one or the other either. I did have a pool years ago I ran with De and HTH which was the only real option back then.
    Sure the whole thing could be smoke and mirrors. The chemistry says chlorine should not work well with Ozone, but if it is working I think it should be ok to share that.
    I am sure there are many, many people that use SWG or BBB only that have very clean water as good or better than my pool. The only reason for my post is if people that have success with different equipment or processes they should share their results.
    The reason I have the trio was the owner of the pool company recommended it on me before I found this site. I almost pulled it out, but did not and as of today not unhappy with it. Could die on me tomorrow, cold have an algae out break etc.
    Tredge- How do you turn off the Ozone on the Trio mine only has 1 control knob for Chlorine production? "I cant see that it does anything." I have no proof it does anything either but I did notice a few things that were different from other pools next to me with similar use, trees etc.. Could be our brand of sunscreen just dissolves easier who knows.
    Again not saying it works for everyone, but so far it is working for us and I guess I am somewhat convinced that this product may actually do as advertised.
    After reading all the negatives around the internet about ozone I broke down and made my pool contractor (Blue Haven) convince me why I should use it. He basically said all the stuff I read on the internet is a lack of knowledge on a true Ozonation system. Since I work in the technology field, I always run into that when the "next generation" technology comes out so I kept an open ear. He explained that they’ve built 155 pools this year alone in our area (Blue Haven’s the largest) and every one of those pools has their SmartPure Ozone System and every one of them say they LOVE it. They say the maintenance is way easier then the SWG system. Basically they say to drop one TriChlor tablet in the skimmer each week and that's (basically) all there is to it. With skepticism I insisted on calling a few past customers and they praised it highly! They said out of all the pools they sell nation wide (which they say are thousands a year) 88% of them are SmartPure Ozone Systems.
    I told my pool designer that I'm going to ignore what I'm hearing on the web and take the plunge. I also told him I’d kick his butt if he stirred me wrong. They told me if it didn't do exactly what they are promising they would install a SWG system for no cost. Sounded pretty good to me...
  1. Ozone or chlorine-above ground pool in FL
    By kimkats000 in forum Pool Equipment & Operations
    Last Post: 03-26-2017, 12:17 AM
  2. New Pool - Del Eclipse Ozone not same as model in quote...need advise
    By jimmerpro in forum In-Ground Pool Construction and Repair
    Last Post: 10-14-2011, 03:40 PM
  3. Del ozone Eclipse 2
    By donnie. in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-22-2011, 12:15 PM
  4. Ozone smell
    By AnnaK in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2010, 02:23 PM
  5. ozone
    By MarkTilley in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-22-2006, 10:49 AM
