Thread: False CYA Readings with metal-out or sequestering proucts
    Dec 2005
    Honolulu, Hawaii.
    Default False CYA Readings with metal-out or sequestering proucts
    Three days ago added Omni's Stain Treat to the pool. The CYA which was at 50-55 read 30.
    As nothing else had changed the guess was that this was the cause of the lower CYA reading. Sure enough this was the reason. It now reads 50-55 again.
    The reason for this post is that it should discourage persons from adding Cyanuric Acid granules until at least three or four days after the sequestering agent has done it's stuff.
    Of couse I am not sure if all sequesting agents have this issue.
    Aloha.
    mbar's Avatar
    Ashland, PA
    Default Re: False CYA Readings with metal-out or sequestering proucts
    This is very interesting. I added sequasol to my pool upon opening. My cya was not changed. Just some info for you. Let's see if anyone else experienced drop in cya with any other sequesterer.
    Northeast PA
    I have never experieced it.
  1. False pH tests
    By Katerific in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2012, 11:40 PM
  2. High Chlorine readings - how do they impact other readings
    By Charlie in forum DPD-FAS based testing
    Last Post: 02-06-2009, 10:41 PM
  3. False CYA reading?
    By ChuckD in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-31-2006, 03:21 PM
  4. Should I use sequestering agent?
    By Amir in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-05-2006, 04:42 PM
  5. Sequestering agent
    By zelmo in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2006, 01:06 PM
