Hi Ted, If it were me I would not try to get to fancy. I would patch the hole, give it a day to dry and then install it. I have patched skimmer openings before with no problems. Your biggest problem may be installing a used liner. Depending on the amount of shrinkage that has occurred, it may not go in at all. A new liner may be in your near future. Either way, best of luck, Dennis
, stops bullets, (it seems it could)
, it's got to be at least 1/8" thick or more. I'm thinking a patch just won't cut it here. That's why I figured to try and make a drain out of it. I was just wondering if anyone else has tried this.
