Results 1 to 10 of 29
Thread: Hot tub forum???
    Jul 2006
    Default Re: Hot tub forum???
    I am currently looking at a Caldera C-Series. I have found more info and a good dealer. Any ideas about this manufacturer and the model?
    Jul 2006
    Nova Scotia CANADA
    I would LOVE to see a Hot Tub section !
    I have two hot tubs: an old Lifestyles model that I think sucks because it is not energy efficient & doesn't have many jets. & a Beachcomber (model#578) which I love . I would recommend that you check out some opinion forums... I personally thought that epinons.com was a great place to read up on Hot Tubs. ( it helped me pick the brand, anyway)
    feel free to message me if you want more info on either tub that I own
    mohawk is offline Registered+ Thread Analyst mohawk 0
    Minneapolis, MN
    poolandspa.com gave me alot of help on their forum site when we started up our spa 3 yrs ago. I use chlorine to sanitize and I don't waste my money on any copper type of boosters. Hope this helps- They also have a pool forum, but I wouldn't waste my time with that either. Denise
    Jul 2006
    I'm located in Ontario, Canada and am looking at getting my first spa. Keep in mind it gets extremely cold here in the winter. I have researched the available brand names and would like input on which brands to consider and which to stay away from. Ideally I am looking to narrowing me list down and then begin visiting the various stores to consider models.
    Catalina Spas
    Dimension One Spas
    Aber Hottubs
    Hotspring
    Caldera
    Sundance Spas
    Freeflow Spas
    Arctic Spas
    Hydropool Spas
    Serenity Spas
    one of the most important things in buying a portable spa is wet testing. Make sure that the recliners and benches fit your body and are comfortable and that the jets are located properly. If a dealer won't let you wet test then I would look for another dealer.
    I've looked at both Catalina and Hydropool (isn't serenty the same company?), they're quite nice, I liked the Hydro's self cleaning feature....other manufacturers have since adopted that feature too.
    Whereabouts in Ontario???
    Jul 2006
    I'm in Ottawa!
    mikemedic is offline ** No working email address ** Thread Analyst mikemedic 0
    West Virginia
    Can we have a section in here on Hot Tubs? I too have one(Marquis) and have had for years. I know have a small leak and trying to fix. Cant find it with all that damn foam insulation they blow in. I think if I buy a new one I will look for a different insulation system
    Any thought from someone who has a hot tub?
    Mike
