Results 1 to 10 of 29
Thread: Hot tub forum???
Threaded View
  1. #23
    Default Re: Hot tub forum???
    Your water is not clear because the sanitizer is too low....bromine should be about 6 ppm. If you do not add sodium bromide to the water first it will take a long time to get the bromine levels up with just tabs! Several companies make sodium bromide to be used when the spa is filled each time. sometimes it is a liquid, sometimes a power. There are also 2 part bromine systems that use sodium bromide and an ozidizer and dont use tabs. IMHO, the best oxizider to use is bleach. It works as well or better than MPS to convert the bromine ions into hypobromous acid!
