Results 1 to 10 of 11
Thread: New pool-what to do?
    duraleigh Guest
    Default Re: New pool-what to do?
    what do I do next?
    Chlorine, chlorine, chlorine!
    Add enough chlorine daily to keep around 2-4ppm in the pool. You will soon have algae unless you keep the pool sanitized.
    Read the sticky's at the tops of the forums. They will tell you more and give you appropriate levels to balance your water. Chlorine should be your immediate priority.
    Sanford, FL
    CH - important for plaster/concrete pools
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
