Results 1 to 8 of 8
Thread: What does ammonia do to a pool?
    cygnusecks is offline Unconfirmed User Thread Analyst cygnusecks 0
    Orlando, FL
    Default What does ammonia do to a pool?
    I had a spray bottle filled with ammonia that I wanted to use instead for spraying bleach. In a moment of stupidity, I briefly considered dumping the ammonia in the pool to get "rid" of it. I ended up not doing it but was wondering what is the effect of ammonia on a pool maintained with B, B, & B.
    Default Re: What does ammonia do to a pool?
    It would form chloramines.
    Quote Originally Posted by waterbear
    which, if there wasn't too much ammonia overwhelming the chlorine, would continue to combine with chlorine to reach breakpoint and produce nitrogen gas. Either that, or the chloramines would sit around until sunlight hit them at which point they might breakdown, again producing nitrogen gas. Until all of this happened, your test kit would show an increased Combined Chlorine (CC) level (actually, your test kit would show a Total Chlorine level greater than the Free Chlorine level, the difference being Combined Chlorine). If this CC persisted, you'd have to seriously shock the pool to get rid of it.
    Now, aren't you glad you didn't dump the ammonia into the pool?
    Richard
    Sanford, FL
    My answer would be - "pretty much the same as peeing in it ... so... not good"
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    I came across an 'old time pool guy' recipe for reaching breakpoint. Not recommending you try this it and Richard (chem geek) or Ben might want to comment on this.
    (Ben, feel free to move this to china shop if it really should be there!)
    For each 20000 gallons add 1 gallon of anhydrous ammonia and 8 gallons of 12.5% liquid chloine (this will raise the FC 50 ppm!) with pump off for 24 hours. Turn pump back on and let chorine levels drop to normal.
    Seems like overkill to me!
    I'm moving this to a new thread in The China Shop called Breakpoint Chlorination. Follow me there...
    Orlando, FL
    Quote Originally Posted by Simmons99
    Well, how much damage can one "#1" release really do to a, say, 15000 gal pool. I mean with 5-6ppm of cl, 30ppm of CYA, and one bladder full of pee, I bet it wouldn't even register on the CC scale, right? How much pee would it take to be detectable (.5ppm of CC or more) in 20000 gal with 5-6ppm of Cl and 30ppm of CYA? I'm guessing *several* bladder-fulls.
    Sanford, FL
    Don't know - all I know is that is what usually causes "cloudy water" after a kids pool party - which requires a shock to get rid of.
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
  1. Ammonia form CYA this year, but not years past?
    By sabres07 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-31-2012, 07:54 AM
  2. Bees and ammonia
    By dhanger in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-16-2012, 10:30 AM
