Hi John, you do in fact need two rubber and one paper. The rubber ones seal and the paper one allows the outer nut to tighten without binding on the rubber one. Order, inside piece with one rubber gasket, insert through precut opening, second rubber gasket on outside next to wall, paper and then nut.
Hope that helps, Dennis
