Results 1 to 10 of 26
Thread: Thanks To All!! Clear Pool At Last
    Jul 2006
    Default Re: Thanks To All!! Clear Pool At Last
    Thanks for the info.
    Had thought about draining some of the water but right now we are on a water ban. I live in Oklahoma and this is the driest year we have had in a long time. I can get by on adding small amounts of water but not enough to re-fill. So for right now I have to contend with the high CYA. Next year will be different though-----------no more tablets for me!!!!!
    Question: Since no hardness shows up should I do something about that? Do I need to add something?
    Thanks for the help.
    Karen
    Karen,
    Is your pool plaster or does it have exposed grout anywhere (on a tile line, for example) or is it a vinyl lined or fiberglass pool? If it's a plaster or exposed grout pool, then you definitely have to have calcium in it, otherwise your pool water will slowly dissolve your plaster and grout. If it's vinyl or fiberglass, then you don't need the calcium.
    By the way, if your pool is plaster or has exposed grout, then any dissolving of the plaster or grout would result in your pH and alkalinity increasing over time just as if you were adding soda ash (calcium carbonate) to your pool. Since you have high pH and alkalinity, perhaps this is what was happening with you (which wouldn't be good -- if your pool surface is plaster, does it look pitted or has it been getting rougher over time?).
    Richard
    Jul 2006
    My pool is gunite--is that the same as plaster? The pool is an older one, I would say 15 plus years. We were told earlier in the season by my ex-pool guy that we needed new gunite at about $6000 --cant afford that at this time so we are making do with what we have. There is some pitting-nothing bad that I can tell though. What is wierd though is that if I check with strips it shows my hardness at 400, but with the drop kit the water does not even turn red.
    Just re-tested my hardness with drops(added cal-hypo last night) and the water turned a very light shade of pink. After 40 drops of titrant the water turned a very light turquoise blue. So now maybe I have some hardness? When I add the 5 drops it sinks to the bottom and I have to stir to mix--is this ok?
    Karen
    Yes, gunite is technically sprayed concrete, but the calcium carbonate that we are concerned with is part of Portland cement that is part of concrete, mortar and most grout. So I've been loosely saying plaster/grout when I should really be saying shotcrete/gunite/concrete/mortar/grout/plaster (what a mouthful!). Technically, a pure plaster (not concrete plaster) is calcium sulfate (usually derived from gypsum) which also needs calcium for equilibrium, but sulfate as well (at any rate, this kind of pure plaster isn't in pools -- only concrete plaster is). But I digress...
    My understanding of typical in-ground pool construction (and my understanding is quite limited) is that they dig a hole in the ground, place rebar, spray with gunite (actually spray concrete in a mixing technique that has this named gunite) and then finish with a concrete plaster surface with some tile at the top that has grout in between. So technically, the sprayed concrete (gunite) and the concrete plaster on top of it as well as the grout between the tiles contain calcium carbonate. So yes, your pool needs calcium (and carbonate, which is most of your TA) in the water.
    As for your calcium test, I don't have the Taylor guide booklet with me, but I do recall it saying something about certain substances interfering with the calcium test, but I don't recall what it is. Perhaps someone else out there on this forum knows what can "bleach out" the calcium test. At any rate, it does appear that you have calcium in your pool and yes, in my experience the deep red drops usually sink to the bottom so you have to mix (shake) to get the pinkish color. If you are doing the test I believe you are, then the 40 drops means 400 ppm calcium hardness which would normally be OK except that you also have high TA (160) and high pH (7.8). That combination in theory gets you close to scaling (precipitating) calcium carbonate though I've learned that this often doesn't happen and you would likely see your water get cloudy first.
    At any rate, we've already talked about you doing a partial drain and refill to try to lower both your CYA and your TA and this will also lower your CH as well, so that's really the easiest way to get down to better numbers. After that is done, then you can repost your results and we can see what else needs to be done, if anything. It may be that you will need to get your TA down even more (to 80-100), but work on one thing at a time (i.e. partial drain and refill first) or else you'll go nuts trying to simultaneously get it all right!
    [EDIT] WHOOPS! Reread your post about the water ban. OK, here's what you can do instead. Follow Ben's procedure for lowering TA by first lowering pH (by adding acid) and then aerating. By significantly lowering your TA to 100, you should be able to have your pH remain somewhat stable at 7.5 and this combination will be better for you given your CH of 400 (it should also have pH rise less and have you adding less acid). With your high CYA, you will need to keep your chlorine up according to Ben's Best Guess CYA chart, but you'll have to live with that (and adding chlorine regularly) until you are able to partially drain and refill your pool again.[END-EDIT]
    Richard
    Jul 2006
    I have some PH Minus left over from the beginning of the summer. Would it be ok to use it. States on side of bottle use 16 oz--thought I would start with 8oz and go from there. or should I buy some acid?
    I have been maintaining my cl level about 8 (per chart) and right now my pool is crystal clear. The grandkids do say that it stings the eyes a little if they are in for quite awhile. I am assuming that this is because of the high chlorine level--correct?
    Sure appreciate your help and PATIENCE that you have shown me
    Karen
    No problem -- we're all here to help each other.
    Can you see what it says the active ingredient is in the pH Minus? It might be Sodium Bisulfate which will add sulfate to your pool. Though that's not the best thing in the world, the amount is rather small since you won't use this all the time so I think it's OK to use this stuff and then in the future use Muriatic Acid (which is a liquid). However, Ben's technique for lowering TA usually takes quite a lot of acid, both for the initial lowering and for the continual adding and testing during aeration, so you might be better off getting the Muriatic Acid anyway.
    I doubt that the high chlolrine level is causing the stinging of the eyes since you've got so much CYA to "hide" the disinfecting chlorine. Usually it isn't free chlorine that stings anyway -- it's usually a pH that is too low (maybe also if it's too high though I haven't heard that before) or its combined chlorine (CC). Your pH is a bit on the high side so that might be it, but it is possible of course that the chlorine levels are causing this (from the "bound" chlorine to CYA) and I'm just wrong.
    Richard
    If your plaster is bad I would stay away from the dry acid....both sulfates and high cya levels have been implicated in pitting of plaster finishes in pools.
    What hardness test are you using? It seems like you are either using the Taylor test or Ben's....there are 3 reagents in this test. If you are using a test that only uses 2 reagents then most likely it is testing total hardness and not calcium hardness.
    Also, what brand of cal hypo is your ace hardware selling? Our store has the HTH on sale and it is only 48%
