Results 1 to 10 of 26
Thread: Thanks To All!! Clear Pool At Last
    Default Re: Thanks To All!! Clear Pool At Last
    Quote Originally Posted by karenkr
    Re-tested my pool. The PH and the TA did not change.
    PH 7.8
    TA 160
    Should I add 28oz. more (per Bens chart)? I guess I am afraid I will add too much.
    Suggestions???
    Chlorine 8 would that have anything to do with my ph?
    Karen
    Karen,
    Did you ever tell us the volume in gallons of your pool? 28 oz. of Muriatic Acid into a pool of 16,000 gallons would lower the pH to 7.44 and the TA to 153.5 so either you have a much larger pool or something strange is going on. With the numbers you show, if you have a larger pool than you won't be adding too much.
    Are you trying to follow the procedure in this thread to lower your alkalinity (TA)? If you want to stop fighting the pH rise and frequent additions of acid, then you'll need to follow the procedure to get your TA down to 100 or maybe even 80. Ben's procedure for lowering TA in the referenced thread has you add a lot of acid to get your pH down and then has you aerate which has the pH rise and you add acid to keep the pH down, all the while your TA will drop.
    Let us know your pool size in gallons so I can roughly calculate what should happen when you add acid.
    There's also a possibility that your high chlorine level is fooling you with your pH test. Usually a level > 10 will cause you problems, but maybe 8 is enough to cause concern. You are kind of in a difficult situation with high chlorine and trying to measure pH (more on that in my next post).
    Richard
    Jul 2006
    My pool size is 35000 gal. I was gong by Bens chart. Just wanted to lower the TA mainly and bring Ph down to 7.2.
    Change of subject: did you see my other post on CYA tablets? Need some help there too!!!!
    With your 35,000 gallon pool and also adding in the 120 ppm CYA that I forgot about (since that also buffers pH), the 28 ounces of Muriatic Acid would have your pH drop to 7.66 and your TA drop to 157 so you might not have noticed this.
    Also, as for testing pH with high chlorine, you can add one or two drops of Sodium Thiosulfate (chlorine neutralizer) which is the same reagent you use in your TA test and mix before you add the pH Indicator Solution. Unfortunately, the Sodium Thiosulfate will raise the pH and give you a falsely higher reading, but only by about 0.1 or 0.2 pH so at least you can get rid of the high chlorine to make sure that you aren't really falsely reading a high pH. My guess is that you are reading correctly since your high TA will pretty much force your pH up, but I'm just giving you another alternative to make sure. In general, you don't use Sodium Thiosulfate with the pH test.
    I'll check your other post on CYA tablets and respond to that separately.
    Richard
