You are getting there if the green is going away. It will be cloudy - that's the dead algae. DON'T add the clarifier - that can make matters worse. You need to get a good test kit to make sure you are really staying at the right chlorine levels.
In your last thread you stated you had CYA of 10 - did you add some since last time? If not - then one of the tests was incorrect - I would guess the lower one - since you are not having faster results.
Get your chlorine to 15ppm-20ppm. The higher your CYA level - the higher your chlorine level needs to be to compensate.
check you filter medium - it may need to be back washed (if sand) or sprayed off (cartridge) - it needs to filter out all the dead algae.
You need some POPP - simple yet difficult for most (Pool Owner Patience and Persistence)
