Results 1 to 10 of 16
Thread: Where can you buy a line blower?
Threaded View
  1. #7
    Default Re: Where can you buy a line blower?
    I don't really understand why you need to blow the lines out.
    I live in the midwest so it freezes every year. All I do is pump antifreeze into each return line, without removing the water, and when I see the antifreeze coming out I cap off the line and fill the rest with antifreeze.
    The main drain I just pump antifreeze into the line until I see it starting to float out and then just leave it. Antifreeze is heavier than water so it stays in place.
    This way may take more antifreeze, but then I don't have to drain the water below the lines, refill it in the Spring or buy a blower.
    I have been doing it this way for about 12 years now and have never had a problem.
