Results 1 to 10 of 13
Thread: No chlorine
Threaded View
  1. #9
    Tucson, AZ
    Default Re: No chlorine
    Quote Originally Posted by aimee3
    Sorry for the delay.. I went out today and the local pool store had NO drop based kits. They dont even sell them. Sigh... So i got a strip test that checks for Ph, Free Chlorine, Alk and stabilizer. Everything is low.. Ph was between 6.2 and 6.8. Free Chlorine is a big fat 0. Total Alk is 40, and stablizier was close to the 0 color. This is the best I can do with numbers at the moment. I will have to get a drop kit tomorrow at Pool City or somewhere.
    Mike- I went to 2 different stores about not keeping chlorine and not ONE of them mentioned adding stabilizer!! Grrrr
    John- we mostly keep it off. The one time we put it on for a few days, the water was green when we took it off. Once I get these chemicals right, I will start leaving it on. Its starting to get a bit chilly at night too.
    Soo.. since everything in my pool is basically low or non existant, can i just start with bleach, borax and baking soda to start fixing my problem. I stopped at Kmart today and bought some of everything.. B B B Im ready!
    You can order the Taylor K-2006 Test Kit directly from Taylor Technologies here (http://www.taylortechnologies.com/) for $68 and free shipping. You can also order PS234 Test Kit from PoolSolutions here (http://www.poolsolutions.com/cart/shopping.php. Either way, you need your own kit.
    Tucson, AZ
    In-ground Gunite
    20,000g
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
