Re: HOT TUBS: Calcium (and Bromine)
chem geek
In fact, I don't believe that hot water in the copper pipes in a home corrode very quickly. Even a hot water heater that has a sacrficial anode to prevent rust does so to prevent the steel tank from rusting -- it's not so much to prevent the copper pipes. In fact, steel has a greater tendency to rust when it is near copper or brass.
So it is possible that if steel is used in spa or pool heaters then rusting could occur, but I think that in these heaters only copper is exposed to the water, not steel.
I certainly want to know if I'm wrong about this or if I'm missing something.
Richard
My understanding is that heaters for hot tubs do not have a holding tank. They use a series of tubes as a heat exhanger that the water flows through from the tub and back....much like 'tankless water heaters' used in homes.
