Thread: SWG pool and rusty screws
    Jul 2006
    Default SWG pool and rusty screws
    I have a IG SWG pool (4 weeks old) and I have noticed that the screws around the lights and some of the returns are starting to rust. I thought they were stainless steel... how does one go about replacing them and preventing them from rusting.
    2900 ppm salt
    6 FC
    5.5 TC
    .5 CC
    160 alk
    180 CA
    35 CYA
    Exclamation Re: SWG pool and rusty screws
    CP, welcome to the foum! Sorry I missed this post before as this is a problem I am currently experiencing on almost all our new SWCG pools. We use Hayward light niches and within a week of adding the salt, the screws on the lights are showing signs of rusting. What we've been doing is replacing the screws. I suspect that Hayward got a batch of improperly coated screws (something in the manufacturing process went awry leaving the screws suseptable to oxidising) What I would do is remove one of the screws (#3 phillips head screwdriver) and take it to the hardware store and get replacement screws that are really stainless. What you should do is call the installer and complain, it's a new pool so the fix should be on him, if staining of the faceplate has occured, ascorbic acid will remove the stains.
    Again, welcome to the forum and sorry for the delay in responding! If you have any more questions, feel free to ask - Waste
    Jul 2006
    Default Re: SWG pool and rusty screws
    Thanks waste! now, can I take out one screw at a time and replace while the unit is underwater? will it leak?
    Country Living in Comal Co., Tx
    Quote Originally Posted by waste
    That's funny, Waste. We just filled our pool about 3 weeks ago and have a SWG. There are 3 Hayward niche lights and 2 of them are fine (so far) but one is rusting like the USS Arizona.
    I thought that the installer must have lost a screw but replaced it with a wood screw or something.......I just hadn't gotten a chance to look at it yet, but I'm going to have to find a good source of marine hardware, it looks like.
    I wonder if I should replace all of them? Good stainless steel is harder to find these days for some reason. A lot of it from Lowes/HD rusts eventually, and is even magnetic! I think they should call it "Stain Steel-less".
    STS
    Just had this problem this year after having liner replaced. One of the screws started to rust 2 weeks after liner was replaced. Must be some poor quality stainless steel out there.
    Jul 2006
    I asked our pool guy and he said that it was a bad batch of screws from hayward, he will replace them with better stainless... hopefully.
  1. New Pool Owner 15X42 Intex Metal Frame - very rusty brown well water
    By Heidi B in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-03-2012, 01:41 PM
  2. replacement stainless steel screws
    By stepbill in forum In-Ground Pool Construction and Repair
    Last Post: 06-08-2011, 01:04 PM
  3. need help with rusty well water
    By shana in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-06-2011, 09:45 PM
  4. stains around screws
    By boscogabby in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-03-2007, 08:37 PM
  5. Loose Screws in Railings For Stairs
    By MrSpeed in forum Pool Equipment & Operations
    Last Post: 05-22-2006, 02:14 PM
