Re: Pump Working Hard with Kreepy Running
Hyetech,
Sully has given you the correct problem,...you're sucking air into the system. If it turns out not to be the O-ring that is leaking, check your hose connections on the kreepy or look for a hole in the hose or look into the skimmer. Somewhere between the kreepy and your pump, there is air getting into the system.
