Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Adding chlorine, how much is safe
FAQ
register
Results 1 to 9 of 9
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
08-11-2006
03:02 PM
#3
Jeffski
View Profile
View Forum Posts
Registered+
Weir Watcher
Re: Adding chlorine, how much is safe
Currently CYA=60, chlorine over 5. Have not added anything to water yet today.
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Pool seems to like it's TA at 70
How much will 4 pucks raise CYA?
Safe to swim with chlorine at 5 ppm?
By feather78 in forum Pool Chemistry for Intex-type Pools
5
Last Post:
06-25-2013,
12:43 PM
What is safe chlorine level for pool vac?
By JimK in forum Pool Cleaning: Manual or Automatic
10
Last Post:
05-11-2013,
11:28 AM
Safe to swim Chlorine levels
By sabres07 in forum Using Chlorine and Chlorinating Chemicals
1
Last Post:
08-01-2012,
06:50 PM
Safe swimming with elevated chlorine
By fcfrey in forum The China Shop
45
Last Post:
09-05-2006,
12:15 PM
Safe Health Level For Chlorine
By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
4
Last Post:
05-20-2006,
06:39 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
