Re: waters still cloudy
I believe you should ignore the pool store advice. Being able to accurately test your chlorine levels (plus other parameters) is absolutely critical to the process of converting to the BBB method of pool water maintenance.
According to the Best Guess Chart often referred to here, you would need to test to a maximum of 15 ppm when you are shocking your pool. I hope your test kit will allow you to test to this level. Many will only go to 5 ppm. If your kit has this limit, you can try diluting your pool sample with distilled (not necessarily bottled) water. The more you have to dilute to get a reading, the less accurate your reading will be.
I am a relative newcomer on these boards, but I can vouch for the results of BBB. Look for more complete advise from some of the more experienced and informed members. They'll be along soon I'll bet.
Jim
16' x 32' / 15,400 gal / IG vinyl
All testing done with PS234 test kit
