Thread: Cloudy Water - Don't know what to do next
    Unhappy Cloudy Water - Don't know what to do next
    Good day all. I'm a new pool kit and chlorine bleach this summer and all has gone well until this past week. My pool was clear last Saturday and we had a gathering of friends that included about 10 kids. I noted on Monday the pool might be a little cloudy so I dumped in some extra bleach. Tuesday it was definitely cloudy so I shocked the pool clear to a free chlorine reading of 17. It got a little worse, then better by Thursday, but no improvement since. It is definitely cloudy, cloudy, cloudy and is probably algae since I have some green accumulating on my steps.
    Here's my test kit results Saturday before the party and before cloudiness:
    FC: 5
    CC: 0
    TC: 5
    pH: 6.8
    Alk: 50
    Cal: 130
    Cya: 90
    Temp: 83F
    Here's my test kit results last evening:
    FC: 15
    CC: 0
    TC: 15
    pH: 7.0
    Alk: 60
    Cal: 130
    Cya: 90
    Temp: 85F
    Why am I still cloudy? I know I got the FC to 17 on Tues/Wed. What should I do next?
    Tx for your help.
    Rick
    Default Re: Cloudy Water - Don't know what to do next
    With a CYA of 90, you're not getting the chlorine high enough to kill off the bloom. YOu need to shock it to 20 and hold it there until it clears, which will take re-testing and adding more bleach to get back up to 20, at least 2-3 times daily. Keep the filter running 24/7 and brush it daily while doing this. It'll clear up--you're just not getting high enough with the Cl to compensate for the high CYA.
    Thanks for the info and quick response. Just put more bleach in and headed for 20+.
    In general, do I need to work on getting my CYA down and if so, what should I do?
    Rick
    If you dump 1/3 of your water and refill, your CYA should go to 60. That's easier to maintain (IMHO) than 90. Or if you dump 1/2, your CYA should go to 45--what I consider ideal during the Dog Days.
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
