Results 1 to 9 of 9
Thread: How often do you replace your filter?
    bkny1055 is offline Registered+ Thread Analyst bkny1055 0
    in the Deep Deep Deep south
    Default How often do you replace your filter?
    I bought the house with pool 8 months back never having issues with the pool till the past two months i am thinking its the filter that is not sitting tight so it brings me to the question
    Saint Cloud, FL
    Default Re: How often do you replace your filter?
    Not sure what you mean by "sitting tight".
    We here do not change filters unless there is a very good reason. Eg, if the filter is so old that it is difficult to replace parts, or not satisfied with what the filter is doing.
    To better answer your question, could give us more details about the filter and your particular pool system, i.e. pool type, size in gallons, pump size, chlorinating method, etc.
    Pat
    sucks through filter bottom
    comes out through here
    and it looks like the pressure is moving the filter on the top and
    allowing dirt to come out and bypass the filter going back into the jets
    on the bottom
    i have this filter housing
    it has a paper filter inside model# Unicell C9699
    Saint Cloud, FL
    Looks like a cartridge filter. It will have to be replaced. I would a Google search with that model # cartridge and see what happens.
    Good luck.
    Pat
    Sacramento, CA, USA.
    It might be a good idea to go ahead and get the cartridge as a spare. Jacuzzi will soon no longer be manufactured and parts (including after-market like the Unicell cartridge you have) may become harder to find.
    They only need replacing when worn out. Are the bands torn? Is the fabric "hairy?" Will it not clean and allow water through it?
    To: thepoolman1
    I just bought a new cartridge
    Thanks for the heads up on them not selling it soon
    It was not worn our
    It had a torn Band " yes "
    Fabric Hairy " yes "
    not clean and allow water through it " YES YES " i guess i needed a new one
    Thanks for the information
    To: PatL34
    Yes i just bought a new one seems like the rubber on top is going bad and has a broken band
    I searched on www.google and www.pricegrabber.com they are about
    60.00 bucks so instead of just waiting on shippment i went to pinch-a-penny and got one off the shelf sometimes best for 70.00 bucks
    Thanks guys for the information i will keep you posted on my pools condition
    Hmm the filter is working like a charm and clearing up my pool
    here are my numbers
    Bottom of pool clear
    Water a bit cloudy but clearing up
    25,000 gallon pool
    Vinyl liner in ground pool
    Alkalinity 130
    PH 7.8
    CL 10+
    Stabilizer 50
    I have been adding 3 gallons of clorox 6% for the past 3 days
    its finally giving in and turning clear
    thanks to everyone on this forum for the information its much appreciated
    Jul 2006
    Nova Scotia CANADA
    BNKY,
    you could buy filter cleaner as well ( chemical that eats all the gunk up) if replacements are expensive or difficult to find.
    I wouldn't worry that much about unicel not making your size though; I have one very old hot tub that was discontinued ( maybe in the 80s..?), but can still get filters for it through them
    thanks RavenNS for the info, my filter was looking old, this new filter works like a champ along with my new Baracuda G4 levels also looking good and holding
    25,000 in ground Gallon Pool Jaccuzi Filter with C*9699 paper filter in it
