Thread: Program to record testing results?
Threaded View
  1. #2
    Northern Kentucky
    Default Re: Program to record testing results?
    I have an Excel spread sheet that I just designed. It is pretty much just for record-keeping, but I did put in some 'conditional formatting' so if a value is outside the recommended range, the font will be a different color. Just a small help to me so I don't have to always be comparing values.
    I also put the CYA chart there. I plan to modify it (ETA: the spreadsheet*) after we actually get the pool with an area that will tell me how much to add to MY pool (ex: 2 2/3 cups 6% bleach to raise Cl by 1 ppm, if I get a 10000 gal pool)
    This is for an AG pool that I plan to keep CYA at 30-50; no heater, so I am not worried about CH.
    (Edited) PM me if you are interested in a copy. You may feel free to modify it if you wish.
    *ETA: I did not mean I would modify the Best Guess CYA chart I meant I would modify my spreadsheet to include such things as how much bleach I need to raise my pool 1ppm.
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
  1. Testing results
    By jcwr56 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-02-2012, 07:05 PM
  2. Three months in the program
    By Water_man in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 02-26-2009, 12:01 AM
  3. testing results
    By minermom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-01-2008, 07:41 AM
  4. CYA Testing Results
    By Simmons99 in forum DPD-FAS based testing
    Last Post: 09-19-2006, 10:48 PM
  5. Testing results, need advice
    By mer1844 in forum DPD-FAS based testing
    Last Post: 06-26-2006, 12:07 PM
