Possibilities:Originally Posted by pedsrn
There may be some additional possibilities, but those are all I can think of at the moment.
- Leakage / splashout, followed by water replacement. (Not very likely, since it would require that you lost 75% of your water in a single episode, or even more, if you lost, say, 50% per episode.
- Scaling / precipitation. (Is your pool slimed, with what feels like sand on the liner / ladder / light rings under the slime?)
- Testing error. (Have you changed test methods, or replaced old test strips with new ones? Test strips are inaccurate, but get much worse over the summer as moisture from the air or your fingers causes them to deteriorate.
Ben
"PoolDoc"
