Re: Some numbers .. Hardess ?
Maybe I should play with the setting a little to see how much higher I have to set it to increase the chlorine to 5. It's a new system and I have been running it for 8 hours a day (overnight ) at about 30%.
I bought a much bigger cell than needed for my pool so I could run a lower setting . Is there a chart available that shows the increase achieved bases on extended run time or higher cell output ? I'll take a look at the manual when i get home but don't remember seeing anything.
