Results 1 to 10 of 12
Thread: " Unattended Puck feeders " & the uninformed
    Default Re: " Unattended Puck feeders " & the uninformed
    Richard, I don't have anything to aerate the pool except my kids But we haven't been in the pool for over a week now and I just tested - pH is 7.6 and TA is 90. Right where they should be...I usually run the pump only but once a week or so put the barracuda in. If we have a bad storm (I live in South FL) on its way I will shock prior to it coming, but really, other than testing and adding tabs as needed that is about all I do. If I need to adjust the pH I use Borax I buy in the grocery store.
    Thanks for the info. You've got yourself a miracle pool! If it were fairly new or newly replastered, then the curing of the plaster would have a rise in pH, but... OK I'll stop trying to figure out why you aren't seeing as much of a drop in ph when using Tri-Chlor tabs nor having your CYA go through the roof like it did in my pool. Must be that Florida sun and rains (I lived in Boca Raton for a year, so I'm jealous that you've still got swimmable weather).
    You're very welcome, and sorry I can't help you more! This pool came with the house which was built in 1987! It's in really good shape (the previous owners took very good care of it) and other than the acid wash we haven't had to do anything...but in a couple of years we're going to have to have it resurfaced for sure...meanwhile, I enjoy using it and looking at my sparkling clear water...and I understand the jealousy - we got a pool heater a couple of years ago so we could swim ALL year instead of just 9 months...LOL!
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  4. a question for the "puck gurus"
    By duraleigh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-22-2006, 12:21 AM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
