Results 1 to 10 of 13
Thread: Foam Bottom
    Warwick, R.I., U.S.A..
    Default Re: Foam Bottom
    Quote Originally Posted by Ltvanloon
    I was considering using Foam as opposed to a sand bottom in the pool I am going to install. When I inquired at the lumber yard they said the dense Blue foam is only sold in 2' widths. Is this correct ? It would require a lot of taping.
    What tape is best duct tape or the red insulation tape? Also the soil here is very sandy. Would tamping the sand down and placing the foam on be sufficient. Thanks in advance, Ltvanloon.
    Not so sure you want to do that, I can see one of two things happening:
    1. The weight of the water will crush it flat and it becomes as good as having nothing there.
    2. It doesen't crush flat but you end up with all kinds of foot dents in it from the swimmers. When you in the store push your thimb into a sheet, it does not come back up.
    But I believe yes, 2'X4' is the size it comes in.
    Wayne
    Morris, IL
    You can get it in 4x8 sheets too, probably just not there, look around I am sure that you could find it. I used the happy bottom stuff, it is more forgivable.
  1. Can't get bottom flat, can pool bottom be slightly concave/bowl shaped?
    By SkierDude in forum Intex-type Pool Setup & Operations
    Last Post: 06-30-2013, 12:13 PM
  2. Foam bottom and Cove
    By CliffTex in forum Above-Ground Pool Construction & Repair
    Last Post: 09-11-2006, 02:04 PM
  3. Do you HAVE to use a bottom and foam?
    By denanbob in forum Above-Ground Pool Construction & Repair
    Last Post: 06-11-2006, 11:33 AM
  4. Foam bottom with sand cove
    By scottfly in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2006, 10:04 PM
  5. Foam Bottom
    By nicker in forum Above-Ground Pool Construction & Repair
    Last Post: 04-27-2006, 01:54 PM
