Thread: Pump motor life?
    Default Re: Pump motor life?
    Quote Originally Posted by Poconos
    It's better to use a thin, flat file to dress the contacts but you can also use some 400 grit wet-or-dry paper available at auto stores.
    That did the trick, Al. Easier than I thought, so I had delayed getting out in the heat to work on it. Today we had showers, cooled things down, tried your suggestion, worked well. Thanks for the sound advice!
    Paul
    Honesdale PA
    Thanks for the comment. Glad to hear things work out well once in a while.
