Closed Thread
Results 1 to 10 of 12
Thread: ladder: anchors how high?
    Default ladder: anchors how high?
    Hey everyone, Have been swimming in the pool the last month but have not had time to finish the deck until now. Need to figure out what height to se the anchors for the ladder and rail. The pool is vinyl lined Cantilever coping. Getting ready to pour the top concrete collar around the pool and then the pavers will go over this to form our deck and hang over the edge of the pool. Question is do the anchors need to be set into the concrete if so what is the level/ how much of the anchor needs to be exposed? Thanks chris
    Blding 18x36 IG vinyl rectangle with custom inpool steps, 22,000 gallons. Chris In Chapel Hill, NC [email protected]
    GutierrezPlastering Guest
    Default Re: ladder: anchors how high?
    When i have set the anchors, i usually try to set them above my deck level height about 1/4" from the cantilever copying. Reason i say TRY because they have ended up level. But level is ok too. Reason i say above deck level is so that when winter comes or cleaning needs to be done not much debri gets into the sockets. But level is ok too.
    I agree completely with GP! The anchors need to be secured in concrete. They also should be able to drain (if you have to, put a tube in the bottom hole, so that the anchor cup drains), a lot of deck guys seal the cup with concrete, which is bad. Having them set a little higher than the deck keeps water and debris out of them (the 'escuchon' (sp ?) plates will hide the difference).
    Thanks guys, One more question. which way should the bolts face.
    duraleigh Guest
    Hi, Chris,
    Good question. I placed the bolts furthest from the pool......not sure that's right but it made sense and worked out OK.
    Talking Re: ladder: anchors how high?
    Us7 - the facing of the bolts doesn't really matter for a ladder. The thing you want to avoid is not having enough room to conveniently get a wrench on the bolt to remove or install it (some rails have the 2 ends ~6" from each other and loosening or tightening the bolt is a real pain because you can only get partial turns on them). Otherwise the positioning of the bolts doesn't come into play, as long as you have escution plates it's not a matter of aesthetics.
Closed Thread
