I agree completely with GP! The anchors need to be secured in concrete. They also should be able to drain (if you have to, put a tube in the bottom hole, so that the anchor cup drains), a lot of deck guys seal the cup with concrete, which is bad. Having them set a little higher than the deck keeps water and debris out of them (the 'escuchon' (sp ?) plates will hide the difference).
