Closed Thread
Results 1 to 10 of 12
Thread: ladder: anchors how high?
    Default Re: ladder: anchors how high?
    thanks for the input. Had the Bobcat out and grading last night. Finally starting to clean up around the pool and retaining wall. looking more like a finished pool and less like a a bomb site. Chris
    Blding 18x36 IG vinyl rectangle with custom inpool steps, 22,000 gallons. Chris In Chapel Hill, NC [email protected]
    On a different topic, how much over hang do you guys recomend for coping. I am getting ready to install my pavers after I set the top concrete collar. Do not really know what the rule of thumb is. Thanks chris
    Cool Re: ladder: anchors how high?
    Chris, the overhang is pretty much up to you, as a rule of thumb, the more overhang, the less secure the coping will be ( not that the difference between 3/4" and 1.25" will mean that your coping's going to fall in the pool). The real issue is how wide the pavers are, I would not feel comfortable having less than ~80% of the coping secured to the beam (& would be more comfortable with a higher %). I would suggest going with ~ 1", pick something that will allow you to use an easily available 'guide', having them ~'perfectly' straight is the 'cap stone' ( ) of the look of your pool. Good luck with the finishing touches!
    thanks guys , an Inch sounds about right.
    GutierrezPlastering Guest
    another thing you may consider before the concrete is done, is to put tape underneath the anchor sockets so that concrete doesn't get accumulated inside of the socket, and don't worry when it rains the water will manage to make a way out and go into the ground. And yes the best way to set the sockets is opposite of the pool copying meaning away from it so that it will be easier to use a wrench to remove the ladder
    Thanks for all the feedback. I put A long piece of #6 copper bonding wire I had laying around down throught the hole and into the ground. pulled out the wire before the concrete was too hard and had a hole for the water to drain into. Pour turned out great. Now to get the pavers in and set. That will have to wait as I am in WV in PA school during the week now and time is limited. Chris
Closed Thread
