Closed Thread
Results 1 to 10 of 12
Thread: ladder: anchors how high?
    Cool Re: ladder: anchors how high?
    Chris, the overhang is pretty much up to you, as a rule of thumb, the more overhang, the less secure the coping will be ( not that the difference between 3/4" and 1.25" will mean that your coping's going to fall in the pool). The real issue is how wide the pavers are, I would not feel comfortable having less than ~80% of the coping secured to the beam (& would be more comfortable with a higher %). I would suggest going with ~ 1", pick something that will allow you to use an easily available 'guide', having them ~'perfectly' straight is the 'cap stone' ( ) of the look of your pool. Good luck with the finishing touches!
    Default Re: ladder: anchors how high?
    thanks guys , an Inch sounds about right.
    Blding 18x36 IG vinyl rectangle with custom inpool steps, 22,000 gallons. Chris In Chapel Hill, NC [email protected]
    GutierrezPlastering Guest
    another thing you may consider before the concrete is done, is to put tape underneath the anchor sockets so that concrete doesn't get accumulated inside of the socket, and don't worry when it rains the water will manage to make a way out and go into the ground. And yes the best way to set the sockets is opposite of the pool copying meaning away from it so that it will be easier to use a wrench to remove the ladder
    Thanks for all the feedback. I put A long piece of #6 copper bonding wire I had laying around down throught the hole and into the ground. pulled out the wire before the concrete was too hard and had a hole for the water to drain into. Pour turned out great. Now to get the pavers in and set. That will have to wait as I am in WV in PA school during the week now and time is limited. Chris
Closed Thread
