Thread: Chlorine testing and copper Algaecide
    Default Chlorine testing and copper Algaecide
    Does copper algaecide (colloidal) interfer with the chlorine test?
    Default Re: Chlorine testing and copper Algaecide
    Quote Originally Posted by Patrick Block
    No, it will not. Any idea how much copper you have?
    David
    No, but copper turns blond hair green, and does the same to nails. It turns fittings green and it's not too good to ingest.
    i never, EVER use copper algacide.
    Thanks for the responses, let me give some background. I purchased a house with a 16X32 IGP vinyl liner about 15 years ago and struggled the first 3 years with persistant algae. Until I tried copper, it was my savior! Not a bit of trouble. I use about 1 pint per season and have amazing water. The only thing I noticed was very low to nonexistant Cl readings even immediately after application (I use 90% granular). Since the water was perfect I added Cl as I saw fit ( not too scientific I know ) and all was well.
    As a note, I never have seen any ill effects from copper and have recommended it to several friends who have also had great sucess however some have also noted the Cl problem I have?
    This year I opened the pool very late into the season and although the water was clear there was a layer of green growth on the bottom, of course the kids were in a rush to get in so I added about 1 pint of copper ( enough for an entire season) and I haven't had a Cl reading since. This issue has always bothered me so I turned to the internet and found Pool Solutions, thanks for all your efforts this is an amazing site. Now with some proper guidence (those pool stores are a mess) I look forward to learning all I can. Thanks again,
    Patrick
  1. Regular use of copper as an algaecide ...
    By paulshikleejr in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-22-2011, 03:34 PM
  2. Copper fittings and chlorine
    By LukeNorris in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2007, 12:06 AM
  3. Chlorine & Algaecide addition's in the Winter
    By donfranko in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 12-01-2006, 09:17 PM
  4. Copper and Cl testing
    By Patrick Block in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-29-2006, 09:18 AM
