Re: Have a small above ground pool, please help
I added 6% bleach, best guess amount for shock yesterday.
Using shot glass method, CL is still at 10-11. I added the same amount this morning for shock level, tested this evening and no change in CL.
I also added some borax yesterday, PH is about 7.5 now up from almost 7.0.
Alkalinity has risen to 200ppm.
stablizer is still at 50. No hardness detected.
Should I keep adding bleach? How long should it take the shock to run the CL down?
The water looks a little better. It wasn't super cloudy before, just slightly. Now it's just somewhat hazy.. hard to explain... it's just not sparkling clear like it should be and chlorine is still way high and you can still smell chlorine.
Have been running the filter for 12-14 hours a day.
24' x 52" AGP = 13.5k gallons
Dynamo 2.0 HP pump, Sand Dollar sand filter, Polaris 65 vacuum
