Thread: CHART - Saving from using a Cover if heating your pool
    bbb is offline Registered+ Thread Analyst bbb 0
    Default Re: CHART - Saving from using a Cover if heating your pool
    Excellent link, Spensar! I operated with no pool cover for the first half of last year, then with a cover for the rest of last year and all of this year, and the resulting increase in temperature and decrease in evaporation is astounding. I also think that having the cover on helps me keep the output of my SWG lower than if I didn't, but I am not sure since I haven't used the SWG without a pool cover.
    If you need justification to buy a more expensive solar cover reel -- one that makes using a cover less of a challenge -- the payback is really short!
    bbb = bleach, borax, & baking soda
    agree with all..i am really amazed at how much less evaporation occurs thanks to my solar cover...i also note that given my pool heater is out of commish and the pool isn't swimmable, i've simply left the cover on a lot more. i suspect that the cooler pool temp has helped, but even with it on days at a time in 25 to 29C weather, i've had little to no algae..
    now, if only i could get my new pool heater going!
    THAT would explain my low chlorine usage!!!
    Thanks for those links!
  1. Saving money on salt
    By famousdavis in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-07-2013, 03:32 PM
  2. saving on reagent for chlorine testing
    By keastman in forum DPD-FAS based testing
    Last Post: 04-07-2012, 04:46 PM
  3. solar cover on/off for best heating?
    By poolbee in forum Pool Equipment & Operations
    Last Post: 05-25-2007, 02:02 PM
  4. Thanks for saving my 4th!
    By ds_girl in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2006, 08:19 AM
  5. Saving electricity - replacing an old pump/motor
    By pauster in forum Pool Equipment & Operations
    Last Post: 06-08-2006, 09:48 AM
