Thread: What PSI does PVC need to be?
    Crispyc21 is offline ** No working email address ** Crispyc21 0
    Woodbridge, VA
    Default What PSI does PVC need to be?
    I have two slow leaks I知 going to take care of this year. I値l have to replace a short run of PVC piping, a couple 90degree turns and two screw-in connectors (one from filter out and the other screws into multi-switch in side (the thing that you switch between filter/backwash..exc).
    Should I be able to get this stuff at Home Depot or Lowes?
    duraleigh Guest
    Default Re: What PSI does PVC need to be?
    Yep! Get Schedule 40. It's printed right on the pipe...sometimes as (sch. 40)
    Dave S.
    Woodbridge, VA
    Great thanks!
