Converting to BBB
After my first (frustrating) season I have decided to make the switch to the BBB method. I've reviewed the beginners guide and many of the sticky notes posted, but I still have a few questions (that I did not see mentioned).
1) PH- I have read that you use either Borax to raise or Muiatic acid to lower. I still have quite a bit of pool store product called PH-UP and PH down. Can I just use this to keep my PH in-line until I run out and switch to the Borax/M. acid ? If it's the same stuff is the reason to go with Borax/M. acid strictly an economical issue?
2)PH- Also unless I missed it (very possible) I did not see a reference to the amount of Borax/M acid to use to reach desired PH levels.
3) CYA-I have read here that you can add pool store stabilizer to increase CYA, but what do you use to lower CYA?
- You may not post replies
- You may not edit your posts
Forum Rules
