As for the amount of Borax to add to raise pH, I now have this in my spreadsheet and can calculate that for you if I know your starting pH, TA, CYA (estimate) and pool size (in gallons) and your desired pH. In the meantime, the advice of adding a little and seeing the results is good.
As an example, let's say my pH is 7.3, TA is 100 and CYA is 30 and that I want a pH of 7.5. Then in a 10,000 gallon pool one has to add about 19 ounces of Borax. You would add proportionately more Borax in a larger pool or for a larger pH change.
Richard
