I was wondering if anyone knows how to get the hardness up in an above ground pool. We are using a swg.
Thank you!
Lil Bit
Thank you!
Lil Bit
Chlorinate with Calcium Hypochlorite is the simplest if you're not in a hurry. Why do you think you need to? Test results would be very helpful.
The total hardness was 117 when tested and our chlorine is up too.
Thanks!
You do not need to increase calcium hardness.
