Results 1 to 8 of 8
Thread: Using Lots of Bleach
    Default Using Lots of Bleach
    I have a 16 x 32 above ground pool, 12,500 gallons. I just recently converted to Chlorine from Baquacil. I'm using about 3 Liters of Bleach every day to keep my chlorine levels up. Does this sound excessive or about right? I realize every pool is different, just want to make sure I'm on the right track.
    My pool is in direct sunlight all day with no solar cover and I live in Texas with 100 degree weather almost every day. My numbers from this morning are posted below.
    I am holding chlorine overnight, but just by the time I get home from work they are usually down to .5 and I have to add 3 Liters to get them back up. I haven't gotten Ben's kit yet, so I'm using a Walmart Kit so I only have total Chlorine.
    CL= 3
    PH=7.2
    TA=120
    Hardness=Nothing (color didn't change)
    CYA=50
    Upstate, NY (Dutchess County)
    Default Re: Using Lots of Bleach
    I ran and compiled a Bleach Usage Survey a little while back...
    http://www.poolforum.com/pf2/showthr...ighlight=usage
    Totally emperical but it'll give you a rough idea.
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    jenpen400 Guest
    Those numbers are very similar to mine AGP 100 + every day cya 50 I'm using .75 gal every other day. I have too kids in diapers (lots of organics in pool bugs leaves). I went through period of time when it seemed I using .75 gal every day and when I shocked the pool It went back to normal. It seems I had a little something growing this spring eventhough I had clear water and no CC.
    Hope this helps
    jennifer
    Thanks for the info guys, I think I'm pretty much on track, maybe usage is a little high, but my pool is in direct sunlight all day, almost 12 hours, so I can expect to use more bleach. Even putting in 3 Liters a day, I'm still only spending $40 a month. I was spending $100 to $150 month on baquacil. So, I'm really happy!!
    BTW jenpen400, I'm also in San Antonio Texas. Actually right outside in Schertz.
    mbar's Avatar
    Ashland, PA
    At a cya of 50 you are at the low end of your chlorine chart. With such high temps, you may want to run your pool on the higher end of the chart, closer to 6ppms. You may be battling a little something in the water that you are keeping at bay with the amount of chlorine you have in the water - you may want to shock, just to be sure.
    Northeast PA
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    I've got a 27,000 IG in direct sunlight from 8:30 am to sunset and I'm using a large jug (about 1.3 gallons) just about every day. Our air temps have been in the upper 90s and low 100s for a couple of months now also.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    Jaybird,
    When you did the conversion from Baquacil did you change your sand? I have a 21k gallon pool in direct sun all day long as well and I have to add a jug of bleach every day, the 6% .75 gallon size. We found it at a Sav-A-Lot for .99 cents a jug!
    court475 Guest
    I'm using 3 liters a day in my 14,000g+ pool. It gets a lot of sun though. It costs lest than $10/week, so I guess that still good!
  1. Lots of rain lately...
    By Leehicks79 in forum Dealing with Algae & Slime
    Last Post: 07-02-2013, 06:05 PM
  2. Lots of algae, 0.5 CC
    By zoffPool in forum Dealing with Algae & Slime
    Last Post: 09-19-2012, 09:44 PM
  3. Lots of questions...
    By melanieholloway in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2011, 06:38 PM
