Results 1 to 8 of 8
Thread: Using Lots of Bleach
    mbar's Avatar
    Ashland, PA
    Default Re: Using Lots of Bleach
    At a cya of 50 you are at the low end of your chlorine chart. With such high temps, you may want to run your pool on the higher end of the chart, closer to 6ppms. You may be battling a little something in the water that you are keeping at bay with the amount of chlorine you have in the water - you may want to shock, just to be sure.
    Northeast PA
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    I've got a 27,000 IG in direct sunlight from 8:30 am to sunset and I'm using a large jug (about 1.3 gallons) just about every day. Our air temps have been in the upper 90s and low 100s for a couple of months now also.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    Jaybird,
    When you did the conversion from Baquacil did you change your sand? I have a 21k gallon pool in direct sun all day long as well and I have to add a jug of bleach every day, the 6% .75 gallon size. We found it at a Sav-A-Lot for .99 cents a jug!
    court475 Guest
    I'm using 3 liters a day in my 14,000g+ pool. It gets a lot of sun though. It costs lest than $10/week, so I guess that still good!
