Thread: Bromine question
    Sanford, FL
    Default Re: Bromine question
    Don't know - are you using this in a spa or pool? PH can be raised if the PH is low and you aerate (spa jets) or when plaster is curing.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Jul 2006
    its for a hottub, not connected to the pool. PH always seems to be high, wondering if its because of the bromine or the constant bubbles (aeration)
    Ft Lauderdale, Fl
    Bromine is normally about 5 - 6 pH so is on the low side.
    Increasing pH will be mostly due to the aeration, make up water quality, and many other additives to your spa (scents, bath oils, sweat, etc).
    Sean Assam
    Jul 2006
    Thanks, I better stop sweating in the hot tub
