Results 1 to 4 of 4
Thread: Hardness
    Jul 2006
    Default Hardness
    I was wondering if anyone knows how to get the hardness up in an above ground pool. We are using a swg.
    Thank you!
    Lil Bit
    duraleigh Guest
    Default Re: Hardness
    Chlorinate with Calcium Hypochlorite is the simplest if you're not in a hurry. Why do you think you need to? Test results would be very helpful.
    Jul 2006
    The total hardness was 117 when tested and our chlorine is up too.
    Thanks!
    duraleigh Guest
    You do not need to increase calcium hardness.
